Skip to Main Content
The official VEX IQ Robotics Competition Question & Answer system has closed for this season.
Official Q&A: VEX IQ Robotics Competition 2024-2025: Rapid Relay
2232: Clarification of removal of balls due to RSC8 and Q&A 2193
Kevin Li (Event Partner)
28-Oct-2024
Given the change to <RSC8> from Q&A 2193, are the balls in the scenarios listed in Q&A 2152 considered in the field and must be removed when resetting the robot via <RSC8>?
Answered by committee
31-Oct-2024
When a Robot is reset under rule <RSC8> in an Autonomous Coding Skills Match, all Balls should be removed from the Robot and the Field. Balls can then be reintroduced through the Loading Station or as Rapid Loads.
If a Ball is stuck in a Switch at the time of a Robot reset in an Autonomous Coding Skills Match, it should be removed from the Field by a referee or Drive Team Member when the Robot is reset. If a Switch is held in a Cleared position (no longer parallel with the front face of the Goal Wall) by the Ball that will be removed, that Switch should be manually moved into a "fully" Cleared position during the reset. The Ball that was stuck in the Switch should not be counted as a Goal.
