The official VEX IQ Robotics Competition Question & Answer system has closed for this season.
Official Q&A: VEX IQ Robotics Competition 2024-2025: Rapid Relay
2317: Autonomous Skills Rapid Load Clarification
Per our understanding, after the match has begun, adding balls to the field can be done either by the (1) loading station or (2) Rapid Load.
There is nothing in the <SG4> rules that prohibit the robot from being in Starting Zone 2 when the Rapid Load balls are loaded. Can you confirm that this is allowed?
Specifically, we're looking at code that would require resetting the robot in Starting Zone 2 per the rules, placing two Rapid Load balls on the field (also) in Starting Zone 2, and then running the robot forward to pick them up before continuing to the Goal Wall to score.
You are correct. There is nothing in the rules that prohibit the Robot from being in Starting Zone 2 when a Ball is Rapid Loaded in a Match, provided the human Loader and the Robot are not in contact with a Ball at the same time.
