Skip to Main Content
This Q&A is now read-only
Official Q&A: VEX IQ Robotics Competition 2025-2026: Mix & Match
2726: Load multiple pins
6183A
19-Jul-2025
<SG6> SG6 does not specify the number of pin to be imported simultaneously. Can I import multiple pin simultaneously。
SG6
Answered by committee
30-Jul-2025
Clauses B and C of rule <SG6> require Pins and Beams to be introduced one at a time.
b. The Scoring Object must be placed in contact with the VEX IQ beam attached to the Floor. c. The Loader may only put a Scoring Object into a Load Zone if no other Scoring Objects are in contact with that Load Zone.
In order to fulfill criterion B, multiple Pins that are Loaded simultaneously would all have to be simultaneously placed in contact with the VEX IQ beam attached to the Floor, also known as the Load Zone. This would violate criterion C because each simultaneous Pin placement into the Load Zone would happen while the other Pins are in contact with that Load Zone.
