Skip to Main Content
This Q&A is now read-only
Official Q&A: VEX IQ Robotics Competition 2025-2026: Mix & Match
2860: Points Clarification
13371A
18-Oct-2025
I would like clarification of this set up. Watching your promotion video my understanding is that this setup totals 91 points. If this does not total 91 pts can you explain why? Thanks
[Example Image]
SC6
Answered by committee
23-Oct-2025
Hello, Team 13371A, and thanks for your question.
We believe that the image in your question shows a Robot that is in contact with the Beam, but not in contact with the Stack below the Beam. If we're incorrect, you're welcome to revise your question and/or image and repost.
Because the Robot is touching the Beam, none of the top 5 Scoring Objects count as Connected or Stacked (see scoring scenario SE10 for a similar configuration). Because the Stack below the Beam is not nested to the Beam and meets the requirements of <SC3> and <SC4>, this scenario would earn points for two connected pins (@ 1 point each), one 2-color stack (@ 5 points), and a Robot in contact with Scoring Objects (@ 2 points) for a total of 9 points.
