Skip to Main Content
This Q&A is now read-only
Official Q&A: VEX IQ Robotics Competition 2025-2026: Mix & Match
2876: Placement of Pins on the Floor Goal during Skills Matches
93558B
25-Oct-2025
<GG4> The Note for <GG4> states, "Any concerns regarding Field Element or Scoring Object starting positions should be raised with the Head Referee prior to the Match. Team members may never adjust Scoring Objects or Field Elements themselves."
Invariably, the placement of the Scoring Objects (Pins) on the Floor Goal will differ from event to event / match to match. These differences could affect a Team's game play especially during Autonomous Skill matches. (1) Is there a more definitive description of where the two (2) red pins and two (2) blue pins should be placed on the Floor Goal other than the picture shown in <RSC3>? (2) Are Drive Team Members allowed to request Scoring Objects be moved, within reasonable limits, to accommodate their practice field set ups and, if so, how much movement would be considered seasonable? Rule <T5>Be prepared for minor field variance states, in part, "Field Element tolerances may vary from nominal by up to +/- 0.5" [12.7mm], unless otherwise specified." Scoring Objects (Pins/Beams} are not included in the definition of a Field Element.
GG4  T5
Answered by committee
30-Oct-2025
Thanks, Team 93558B, for your question!
Rule <T5> will be revised in the next game manual update to specify that Scoring Object positions also have a +- 0.5" tolerance. This change is effective immediately.
For consistent setup, the four Pins that begin the Match in positions on the Floor Goal should be in straight lines with the other Pins on the Field.
