Skip to Main Content
This Q&A is now read-only
Official Q&A: VEX IQ Robotics Competition 2025-2026: Mix & Match
3053: Touching a stack
96627A
23-Jan-2026
At the end of a match if a robot happens to still be touching the top pin of a 3 stack, that negates the entire stack value since the 3 pins are nested together. If that stack value doesn't count because it is fully nested, does touching only the top pin of the 3 stack qualify for touching 2 game elements for the 2 points since the pins are nested? <SC8>
SC8
Answered by committee
29-Jan-2026
That is correct. Per clause B of <SC3>, none of those Pins count as Connected due to the Robot being in contact with the resulting Stack.
Per clause B of <SC8>, a Robot that ends the Match in direct contact with a Pin that is fully nested with one or more additional Scoring Objects will receive 2 points for ending the Match in contact with Scoring Objects.
