Skip to Main Content
This Q&A is now read-only
The Official Q and A is now closed. If you want to submit a question for the Worlds Drivers Meeting, please click here. The deadline for question submission is Friday, March 24.
Official Q&A: VEXU 2022-2023: Spin Up
1235: VUR3 And VUR4 Clarification
GHOST
13-Oct-2022
VUR3:
Fabricated Parts may be made using the following processes: a. Adding material, such as 3D printing. b. Removing material, such as cutting, drilling, or machining. c. Bending material, such as sheet metal breaking or thermoforming. d. Casting or molding material, such as injection molding or sand casting. e. Attaching materials to one another, such as welding or chemically bonding (e.g., epoxy).
VUR4:
Fabricated Parts must be made from raw materials. For the purpose of this rule, a “raw material” is any material that would not be considered a “pre-fabricated” part (i.e., has not undergone any of the fabrication techniques listed in <VUR3>
Because casting is a fabrication process listed under VUR3, any material that has undergone casting is not a raw material under VUR4. However, metal billets are cast, and sheet metal and plastic is cast before being rolled. Are billets and sheets of material considered raw material? If so, how does that square with the definition of a raw material given in VUR4?
Thank you!
Answered by committee
As stated in <VUR4>, "For the purposes of this rule, a "raw material" is any material that would not be considered a "pre-fabricated" part." Most billets and sheets of material are made legal under <VUR4a>, as they are finished through standard raw material finishing processes.
If this answer is unsatisfactory and you'd like us to reconsider, please feel free to rephrase and resubmit your question.
