This Q&A is now read-only
The Official Q and A is now closed. If you want to submit a question for the Worlds Drivers Meeting, please click here. The deadline for question submission is Friday, March 24.
Official Q&A: VEXU 2022-2023: Spin Up
1269: VUR3 and VUR4 Follow Up (COTS Gears)
Thank you for your clarification in Q and A entry 1235! To summarize, billets and sheets of material are classified as raw materials and considered legal, because even though they undergo some of the fabrication techniques listed in VUR3, they also undergo some of the finishing processes listed in VUR4. We would like to ask a follow up question, but first, here are rules VUR3 and VUR4 again.
VUR3:
Fabricated Parts may be made using the following processes: a. Adding material, such as 3D printing. b. Removing material, such as cutting, drilling, or machining. c. Bending material, such as sheet metal breaking or thermoforming. d. Casting or molding material, such as injection molding or sand casting. e. Attaching materials to one another, such as welding or chemically bonding (e.g., epoxy).
VUR4:
Fabricated Parts must be made from raw materials. For the purpose of this rule, a “raw material” is any material that would not be considered a “pre-fabricated” part (i.e., has not undergone any of the fabrication techniques listed in VUR3). a. Standard raw material finishing processes, such as extrusion, heat treating, or anodizing, are not considered pre-fabrication.
Our question is whether other parts that have undergone the listed finishing processes are also considered raw materials. For example, most COTS gears are cast, hobbed, or broached, all of which would be considered prefabrication techniques under VUR3. However, COTS gears are then heat treated and / or anodized, which are both considerd raw material finishing processes in VUR4. Are COTS gears therefore raw materials?
If not, what is the distinction between aluminum billets and (for instance) COTS cast aluminum gears? Both parts are cast and then heat treated.
Thank you for your time!
Our question is whether other parts that have undergone the listed finishing processes are also considered raw materials. [trimmed] Are COTS gears therefore raw materials?
No. COTS gears are not raw materials, and are disallowed by rule <VUR4>.
As to the distinction, an aluminum billet is a block of metal—a raw material that is designed to be fabricated into something else (for example, a gear); the other is a gear. which was fabricated for the sole purpose of being used as a gear.
We encourage you to consider rule <G3> and apply common sense when attempting to differentiate between raw materials and fabricated parts. If an item is generally intended to be used in the exact state in which it is sold & purchased, it is unlikely to qualify as a raw material under the VEX U competition rules.
