Skip to Main Content
This Q&A is now read-only
The Official Q and A is now closed. If you want to submit a question for the Worlds Drivers Meeting, please click here. The deadline for question submission is Friday, March 24.
Official Q&A: VEXU 2022-2023: Spin Up
1471: VUR6, VUR4, Belts
WPI
21-Feb-2023
Under VUR6, it's stated that a spring is "any device used for storing and releasing elastic potential energy". Under the definition, would COTS rubber and polyurethane timing belts fall under the category of springs, since their primary function is power transmission via the use of elastic tension? Additionally, would COTS rubber and polyurethane belt extrusion be legal under VUR4? Other legal materials - such as surgical tubing and aluminum extrusion - go about the same manufacturing process, so it would make sense that extruded rubber and polyurethane belt would fall under that rule as well. Thanks!
Answered by committee
Yes, rubber and polyurethane timing belts are legal.
