This Q&A is now read-only
The Official Q and A is now closed. If you want to submit a question for the Worlds Drivers Meeting, please click here. The deadline for question submission is Friday, March 24.
Official Q&A: VRC 2022-2023: Spin Up
1430: <RSC2> Actions Permitted when Moving Between Alliance Stations
Note the bold portion in the rule quoted below.
<RSC2> The Team may utilize fourteen (14) Match Load Discs, within the guidelines set forth by <SG6>.
i. At any point during the Match, one (1) Drive Team Member is permitted to move between the two (2) Alliance Stations for the purpose of introducing Match Load Discs. There may never be more than one (1) Drive Team Member outside of the Alliance Station in which the Team began the Match.
Scenario:
A team is in the middle of a driver skills run. All 3 Drive Team Members started in the Red Alliance Station. A Drive Team Member wishes to move to the Blue Alliance Station. The questions below are about this Drive Team Member.
- Can they move to the Blue Alliance Station and stay there without placing any Match Loads?
- If they move to the Blue Alliance Station and use up every Match Load from this area, are they allowed to stay in the Blue Alliance Station?
- While in the Blue Alliance Station, can they look at Rollers closer to the Blue Alliance Station to check if they're scored?
- While walking towards the Blue Alliance Station, are they allowed to stop halfway so that they're at a location that's not in either Alliance Station?
- Can they walk halfway towards the Blue Alliance Station, check if a Roller is scored, and then walk back to the Red Alliance Station?
Thank you for your time.
- Can they move to the Blue Alliance Station and stay there without placing any Match Loads? 2. If they move to the Blue Alliance Station and use up every Match Load from this area, are they allowed to stay in the Blue Alliance Station? 3. While in the Blue Alliance Station, can they look at Rollers closer to the Blue Alliance Station to check if they're scored?
Yes. All of these are acceptable applications of point b.i. of rule <RSC2> and are allowed.
- While walking towards the Blue Alliance Station, are they allowed to stop halfway so that they're at a location that's not in either Alliance Station? 5. Can they walk halfway towards the Blue Alliance Station, check if a Roller is scored, and then walk back to the Red Alliance Station?
No. A Drive Team Member may move between the Alliance Stations, but they cannot stop to interact with either the Field or other Drive Team Members along the way. Drive Team Members must ensure that they are not blocking the non-Alliance-Station sides of the Field, which must remain open for safety and event volunteers.
