Skip to Main Content
This Q&A is now read-only
Official Q&A: VEX IQ Robotics Competition 2025-2026: Mix & Match
2755: Define entirely within goals
Scott Glass
7-Aug-2025
<SC5c> requires a stack to be "entirely within" a goal to be considered placed in a goal. This is a prerequisite to score the matching goal bonus in <SC6>.
Any stack of two or more pins will rarely be perfectly vertical. Each pin in the stack may be a millimeter or two to the side. Included is a picture of a stack of six pins since it shows this shifting more drastically than a stack of two or three. The stack is pushed into the corner of the triangle goal in a way than the bottom pin is flush with the floor wall and the inside edge of the pipe - clearly within the goal. Each pin shifts further and further toward the outside of the field and crosses the floor wall. The triangle goal is defined by the inside of the floor wall and the inside of the pipe. However, the stack crosses this vertical plane as it gets taller.
Is this stack "entirely within" the floor goal if it crosses the vertical plane of the floor goal boundary?
Similar situations could be created with the square goal and floor goal where the bottom pin is within the boundary but successively stacked pins shift outside the vertical perimeter.
[Example Image]
Answered by committee
14-Aug-2025
The goals (other than the Standoff Goal) are defined as sections of floor, not vertical projections. If the lowest Pin in the Stack is entirely within the Goal's defined section of floor (i.e., not propped up on the PVC or perimeter that surrounds a Triangle or Square Goal, or not extending beyond the defined edges of the Floor Goal) the Stack meets the criteria of <SC5> clauses Ci-iii.
